Pretty weird problem (input)
Solved by ZarosTenjin,
Okay i've solved the problem and it was actually kinda dumb...
it wasnt the OS but the mouse at fault, after spending ages trying to figure out what could be wrong in the OS i went on to check the mouse and the 'mouse wheel right tilt'-button was actually perma in. i prodded a bit at it and it sprung out having the mouses behavior return to normal.
