A dumb connection question
Solved by EarthboundHero,
Do the screws to connect your MoBo to your case, come with the MoBo or case?
Should come with the case.
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases3 -
2
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning18 -
1
play_circle_filled
Latest From ShortCircuit:
