Cooler Master Hyper TX3 Compatibility
Go to solution Solved by xnoobftw,
You can always try it out. My 212x fits in my spec 03 case even though the official CPU cooler max height for my case is
Maximum CPU Cooler Height
157mm
and the height of 212 x is 158mm
Heat Sink Dimensions 116 x 51 x 158 mm / 4.6 x 2.0 x 6.2 inch
212 evo is 159mm
Dimension 120 x 80 x 159 mm (4.7 x 3.1 x 6.3 in)
I would say give it a try for your case before deciding. The 212 series is a really good low budget CPU cooler series!
I was wondering if the CM Hyper TX3 is any good with an i7 4790k? I can't get a 212 EVO because my case (Aerocool xpredator x1) won't allow the cooler to fit in. If you know any better coolers that are near the same price as the 212 EVO and is under 158mm please let me know!
https://linustechtips.com/topic/271125-cooler-master-hyper-tx3-compatibility/
157mm
212 evo is 159mm
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
My 212x fits in this case, thats something
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
