Current Rig
CPU: Intel Core i7 4770k Haswell
GPU: NVIDIA Geforce GTX 770 2GB
MOBO: Asus Z87 PRO (V Edition)
RAM: 16GB G Skill Trident X (2 8GB Sticks)
PSU: Corsair TX750M
SSD: 250GB Samsung 840 EVO
HD: 1TB WD Black
I feel like with the new graphics cards on the market it's time for an upgrade. I'm powering a dual monitor 1080p setup. My budget is around $1k.
Any recommendations? What would be the best bang for my buck option for a lasting new GPU?
Thanks
https://linustechtips.com/topic/270923-need-help-on-upgrading-graphics-card/
well You don't really NEED a new one, but if you are looking at that price I'd say go dual 970s, or if you can push your budget a bit triple 970s.
Although personally I'd say get dual 970s and put the extra money into a third screen
Please use http://pcpartpicker.com/ for everybodones sake!
and quote me if you want me to see a reply please :)
pewpewpewphysicslazers!!!
Single GPU? GTX 980.
If you want to use that full $1K? Get two 980s. (2x 980 can be had for about 1.1K USD)
for two 1080p monitors? I think dual 970s are the better bang for his buck and doesnt have to spend 75% of his money :P
PROJECT MOGARCPU: i5 4690k @ 4.9 Ghz CPU CoolerCorsair H100i in Pull on top Motherboard: Gigabyte Z97X-Gaming GT GPU: Gigabyte GTX 1080 G1 Gaming Edition RAM: Corsair Dominator Platinum (2x8GB) 2133 Mhz  PSU: EVGA G2 850W SSD: Samsung EVO 840 250 GB HDD: WD Black 1TB Case: Cooler Master CM Storm Scout II
For around a grand you could get a 295x2 and still have some money to spare. It's the fastest card you can get on a single pcb. Since you only have 16x pcie lanes you can potentially add another one for quadfire if you so desire.
CPU: Intel i7 4770k 4.3ghz MOBO: Asus Z87 Sabertooth RAM: 2x8GB RipJaws 1866mhz GPU: 2x GTX780ti SLI 1.2ghz SSD: 960GB 2x Intel 730 RAID0 CASE: Fractal Design Define S COOLING: Custom EK watercooling loop
Very true.
I am kinda disregarding what he says about "best bang for your buck", arent I? 2x 970s will run most modern games at 1080p more than fine, and even if he decides to go with 1440p in the future, games like BF4, Last Light, etc etc, still run at a great 70+ FPS.
Now, if he wanted to use all of his money in this (which is what I was going by), the best use of it would be the dual 980s. For a few reasons. You really wont want toi be looking at 3-way sli of anything:
1. To run 3-way SLI, you need a PLX or HEDT board to support 3-way SLI with z87/97. As Nvidia requires 8x for SLI. (He doesnt have that)
2. The scaling of 3-way sli isn't the best, and will differ from game to game.
3. More cards = more heat+power.
So, the two fastest single cards will be best to keep him going for a few years (until nvidia releases a new $300 card that kills two 980's in 2-3 years) are the 980's (or a couple 295s....).
D3SL91 | Ethan | Gaming+Work System | NAS System | Photo: Nikon D750 + D5200
Wait, are you gaming on both monitors or one for gaming and the other for stuff to be on it while gaming?
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
Single GTX 980 will be good for driving your panel. But suggest upgrading your display to a 1440p monitor.
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
Very true.
well i never said he should 3-way SLI 970s, the performance increase is so little and heat and power consumption is so high it doesn't really justify the price imo.
Do you really think dual SLI 970s wont last 2-3 years? And why should he spend extra money on 980s if two 970s do the job just fine? Bragging rights? I wouldn't even dare but "futureproofing"? Besides, its always nice to save a few pennies :)
Sorry, sounds like my tone is coming across incorrectly in my posts. :(
I'm saying you are 100% correct. I'm not saying you said 3-way sli (Some people recommend it for some reason, and I wanted to mention the problems that may come up with that). I'm not even saying he SHOULD spend the full 1k, All I'm talking about, is if he WANTS to spend his full 1k budget, the best way to max out his budget would be with Dual 980s. Obviously, if he wants to save some cash, SLI 970's will be great, as you said. To sum up:
If he wants one GPU : 980
If he wants two GPU's: 970s
If he wants to max out his 1k budget: 2 980s
oh ywah now it makes sense :P
wouldn't two 980s be slightly over budget? Depending on the manufacturer anyways...
