My asus hd 7870s onboard fan controller appears to have blown and the fans no longer start. Any way to hook them up to a molex or anything?
FX 8350 |  Be Quiet! Dark Rock Pro 2 | Asus Radeon HD 7870 DCUII Top | 8GB 1866MHz Vengeance | 240GB OCZ Vertex 3 SSD | 2TB Seagate Barracuda |
https://linustechtips.com/topic/270901-7870-fan-controller-blew/
just plug them in the motherboard unless you have a fan controller
Its not a standard fan connector though, it has 5 pins, any idea which wire is which?
https://linustechtips.com/topic/270901-7870-fan-controller-blew/#findComment-3675547
I actually bought a 970 recently but returned it after it havi,g really bad coil whine, then this card develops a fault lol, think the universe is trying to tell me something?
https://linustechtips.com/topic/270901-7870-fan-controller-blew/#findComment-3675576
really? try plugging it in anyway if it can fit. you just might not be able to control the speed...
Steve
https://linustechtips.com/topic/270901-7870-fan-controller-blew/#findComment-3675618
Bah its a 5 pin with small holes, I think the only way to hook it up would be to wire it up myself, but I dont know what pins are what
https://linustechtips.com/topic/270901-7870-fan-controller-blew/#findComment-3675797
What is the pinout of your 5-pin VGA PWM mini connector?
Is it: ??
-Pin1-Ground (assume black)
-Pin2-+12V
-Pin3-RPM sense (from fan-1)
-Pin4-PWM signal
-Pin5-RPM sense (from fan-2)
(http://www.overclock.net/t/1447846/5pin-gpu-pwm-connector-to-4pin-standard-pwm-connector)
Steve
https://linustechtips.com/topic/270901-7870-fan-controller-blew/#findComment-3675857
