My Current Build looks like this:
GPU: R9 280 XFX DD Edition
GPU: AMD FX-6300
Motherboard: Gigabyte GA-970-UDP3 AMD 970
RAM: 8Gb Corsair VengeanceLP Dual Kit (2x 4gb) Green
HDD: WD Blue 1TB
Now as for the CPU Cooler I want to get a Corsair H80i later on... For overlocks ecetera... And my main problem is choosing the PSU I want a 650W one since I don't really want to push it all that much over the limit of my budget and id rather have a 280 than one 270x (Which Isnt bad because if I wanted to crossfire them a 750w PSU Would be good deal imho) soo yeah I've been deciding between the EVGA Supernova G-Series of PSU's or the RM Series from Corsair... I Havent heard many good things about the RM Ones expecially because of their capacitors and that they go defect more quickly, also they're alot more expencive and people have told me that they're a rip off
https://linustechtips.com/topic/270865-final-build-questions/
Thanks bruh, and to everyone else I'm still not a 100% sure which R9 280 to take still debating about the XFX one don't know how good it is... And I'd take the ASUS one but it's just too expencive.
The XFX one is really pretty and the cooler is also pretty decent.
i'm a potato
https://linustechtips.com/topic/270865-final-build-questions/#findComment-3675865
FX 6300? Nope. That'll bottleneck anything above a 270X pretty bad. I suggest an i5 4460 for about $180. (Sometimes 160). It'll smoke that FX. Get a cheapo board like an ASRock B85 Anniversary ($50). No aftermarket CPU cooler is required.
You can slap a 290X on that and get no bottleneck to your performance.
Intel Inside. Overweight guy in his 30's outside.
https://linustechtips.com/topic/270865-final-build-questions/#findComment-3675942
Um, what's your budget, and what is the purpose of your rig? Maybe we can get you some better parts. :D
Thanks for asking! Well My maximum budget goes to 650€ Not more not less :D  My purpouse is playing games like BF3/4 On Ultra settings, Games like Company Of Heroes 2 and World of Tanks those kinnda types and some demanding future games... Well I atleast want it to be a little bit future proof... Since this is my first build and like my first other pc after five years  :(
https://linustechtips.com/topic/270865-final-build-questions/#findComment-3680028
Too bad that Intel is too expencive now if the i5 Was 120€ AMD Would loose in the whole bang for the buck department... Suggest me something better then I'd like to keep my Windowed Black Fractal R4 and Perhaps my PSU. I was actually also aiming for a green looking build.
https://linustechtips.com/topic/270865-final-build-questions/#findComment-3680037
with some tweaking, we could get you an i5. Pretty sure your budget is big enough for it. nevermind. Thought I saw pounds but you posted euros.
https://linustechtips.com/topic/270865-final-build-questions/#findComment-3680258
Yeah... that's where I'm getting at... :/ Those damn things are so super expencive I don't really know what to sacrefice now
https://linustechtips.com/topic/270865-final-build-questions/#findComment-3680469
This is about €670, if we do a straight exchange from usd to euro, but with your hardware prices and exchange rate, it'll probably be closer to €800.
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor ($169.99 @ Amazon)
Motherboard: ASRock B85 Anniversary ATX LGA1150 Motherboard ($67.98 @ Newegg)
Memory: Team Vulcan 8GB (2 x 4GB) DDR3-1600 Memory ($59.97 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($51.85 @ OutletPC)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card ($368.99 @ NCIX US)
Case: NZXT S340 (Black) ATX Mid Tower Case ($69.75 @ Directron)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply ($44.99 @ NCIX US)
Total: $833.52
Generated by PCPartPicker 2014-12-16 09:53 EST-0500
https://linustechtips.com/topic/270865-final-build-questions/#findComment-3680676
Total: $833.52
Will keep an eye on that! But how does this build seem? Yes I know it's an AMD one but it's around the 650€
CPU:AMD FX Series FX-8320 8x 3.50GHz
GPU: Gigabyte Radeon R9 270X
Motherboard: Gigabyte GA-970A-UD3P AMD 970
PSU: 650 Watt EVGA SuperNOVA 650 G1 Gold
RAM: 8GB Crucial Ballistix Sport DDR3-1600 DIMM CL9 Dual Kit
HDD: WD Caviar Blue 1TB
Case: Fractal Design R4
Would this be any good? I mean yeah sure the i5 Is good and all... But I'm running a PC that still uses IDE cables on one old samsung HDD of 80gb since my 500gb old seagate sata drive froze up last month and I really need a new PC badly... :(
https://linustechtips.com/topic/270865-final-build-questions/#findComment-3680946
Yeah, that's a great build too. You can always upgrade you gpu up to the 970 if you wanted to. The cpu won't bottleneck it.
https://linustechtips.com/topic/270865-final-build-questions/#findComment-3681197
Really? I would be able to use a GTX 970 with the CPU? Would the PSU Be enough? Since it's a Gold Certified one I guess it would be, damn didn't know I would be able to use the 970 without a bottleneck, thanks alot! Might get it around the summer time or so :) When I save up some more money, since yeah as I said I really need a PC badly now and I don't have more cash than that, damn this made my day seems like I found my build! Thanks! :D Other suggestions are still welcome though for me to reconscider! Oh and the Build you shared with me, converted in Euros is around 668€ as you said well almost 670 :) But I'll see what I can do more, for now I'll stick with what I choose in the previous post and that might be what I'd get mid January
https://linustechtips.com/topic/270865-final-build-questions/#findComment-3681214
I mean if you're not getting it until mid jan, that's plenty of time to invest in an i5 build
:P
https://linustechtips.com/topic/270865-final-build-questions/#findComment-3681227
:P
Hehehe Indeed! :P I'll see what I can do! Keep hitting me with suggestions or tips :) EDIT: Also reccomending a cooler would also be very welcome! Air Cooling(Heatsinks) Any kind I intended to go with the H80i at some point don't know if it's good.
https://linustechtips.com/topic/270865-final-build-questions/#findComment-3681243
Or
CPU:
Intel Pentium G3258 (And Upgrading it 6 months later to an i5)
GPU: MSI Hawk Radeon R9 270X
Motherboard: MSI Krait Z97S
Would this second build last? Yes or no? And yeah what would you guys reccomend more?
https://linustechtips.com/topic/270865-final-build-questions/#findComment-3691151
