I've never bought an OS in my life save from a laptop that had Windows XP already installed on it. How does licensing work for a copy of, let's say, Windows 8? If I change out hardware in my computer will I lose the license for the OS? Will I have to buy a new copy every time I change out something? Is there a way to have Microsoft deactivate the license and transfer it over to a new computer?  I'm asking this for both a copy of Windows 8.1 Pro and Office 2013. I'm assuming you would be able to do the same thing with both. Thanks in advance. :)
https://linustechtips.com/topic/270688-how-does-os-licensing-work/
No, your license will likely remain intact depending on what you're changing out. Changing out a motherboard can cause it. No, you do not have to buy a license every time you change your hardware. If you call Microsoft, you can have your key(s) reset.
I've had multiple reinstalls of Windows 8 on my system, always used the same key never had any problems. I have Office 360 basically just can have two active installs and you download from the website.
The only license that expires when hardware is changed is an OEM license
Intel Core i5 4690K @ 4.2Ghz | Evga GTX 780 Ti SC ACX with backplate | MSI Gaming 9 AC | 8GB (2x4) Corsair Vengeance Pro Silver 2400 MHz | Corsair H105 128GB Crucial MX100 | Toshiba 2TB | Evga 750G2 | Corsair Obsidian 750d | Be Quiet Silent Wings 2 PWM (3x140mm & 3x120mm)
I'm assuming if I swapped out the motherboard I would just have to provide them with a serial number or model number or something to identify it?
It's an automated call. You just have them reset the key. That's it.
If the key is an OEM key, switching out your motherboard will cause it to become deactivated.
Here is a way to tell if its OEM:
"Assuming that your system is still working, right-click My Computer and select Properties.  Scroll down to the bottom of the screen and find the Product ID.
The Product ID should be in the form xxxxx-xxx-xxxxxxx-xxxxx.  What are the 3 characters in the second group (if those 3 characters are OEM, then you have an OEM version)."
If you purchase a retail product key, changing out any part (besides the HDD) will not deactivate Windows.
You can also re-use a retail windows key.
blackshades on
