is it okay?
Go to solution Solved by brob,
And also the motherboard, should I change? Its a newer chipset than H81
If you go with a Haswell Refresh cpu like the i5-4590 then it makes sense to go an H97 or Z97 motherboard. There are a number of choices in the same price range as the H81 in the OP. Also, since the case can take ATX motherboards go with that size. An mATX motherboard will look small in the case and the difference in motherboard prices is marginal.
This build is not less expensive. But it does have 2x4GB of decent memory, an H97 motherboard which will not need a BIOS upgrade before the cpu can be used, and a slightly larger psu.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($174.99 @ NCIX US)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($74.78 @ Newegg)
Memory: Team Zeus Blue 8GB (2 x 4GB) DDR3-1600 Memory  ($61.98 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($52.99 @ Amazon)
Video Card: EVGA GeForce GTX 760 2GB ACX Video Card  ($199.99 @ Best Buy)
Case: BitFenix Neos White ATX Mid Tower Case  ($50.98 @ Newegg)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($54.99 @ Amazon)
Wireless Network Adapter: Asus PCE-N10 802.11b/g/n PCI-Express x1 Wi-Fi Adapter  ($22.11 @ Newegg)
Total: $692.81
Generated by PCPartPicker 2014-12-17 00:12 EST-0500
4GB ram is going to be bad, get 8GB min
| CPU: Intel i7 4790K @4.4Ghz  | GPU: Gigabyte GTX 970 G1 Gaming  | CPU COOLING: FRACTAL DESIGN S36 | MOBO: ASUS ROG Maximus Vii HERO | RAM: 16GB G.Skill Ripjaws X @1600MHz  | CASE: Phanteks Enthoo Pro Full Tower | PSU: EVGA SuperNova 850 G2 850W Fully Modular | HDD: 2TB Seagate Barracuda | SSD: 256GB Crucial MX100 | DISPLAY: Dell U2414H | HEADSET: Corsair H2100 Dolby 7.1 Surround |
https://linustechtips.com/topic/270374-is-it-okay/#findComment-3669053
No there won't be a bottleneck but I would go with 8GB of ram (2x4GB) since dual channel has higher performance than single.
You could also get an r9 280 that would perform better than the 760: http://pcpartpicker.com/part/sapphire-video-card-100373l
MY CURRENT PC
 CPU: Intel Core i7-4770k COOLER: Noctua NH-D14 MOBO: MSI Z87-GD65 Gaming ATX RAM: G.Skill Ripjaws 16GB DDR3-1600 STORAGE: Samsung 840 EVO 120GB SSD and Seagate Barracuda 1TB 7200RPM HHD GPU: Gigabyte G1 Gaming GTX 970 SLI CASE: Fractal Design R4 PSU: EVGA 1000W 80+ Gold
PERIPHERALS - KEYBOARD: Corsair Vengeance K70 w/ Cherry MX Browns MOUSE: Logitech G500/M100 MONITOR(S): Acer H236HLbid (I want an Asus PB278Q) SPEAKERS: Some Cyber Acoustics $10 speakers PICTURES AND FULL PARTS LIST @ PCPARTPICKER - http://pcpartpicker.com/b/z4Pscf
"Don't get so caught up in trying to make a living that you forget to make a life."
https://linustechtips.com/topic/270374-is-it-okay/#findComment-3669081
This is almost $50 cheaper and will be better.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($172.94 @ SuperBiiz)
Motherboard: Gigabyte GA-B85M-DS3H Micro ATX LGA1150 Motherboard  ($45.98 @ OutletPC)
Memory: Team Zeus Red 8GB (2 x 4GB) DDR3-1600 Memory  ($59.98 @ Newegg)
Video Card: Sapphire Radeon R9 280 3GB DUAL-X Video Card  ($169.99 @ Newegg)
Wireless Network Adapter: Asus PCE-N10 802.11b/g/n PCI-Express x1 Wi-Fi Adapter  ($13.93 @ OutletPC)
Total: $593.68
Generated by PCPartPicker 2014-12-14 20:44 EST-0500
sephallanx make sure to follow your own topics.
CPU: i7 5820K 4.0GHz @1.15V | MOBO: Asus X99 Sabertooth | GPU: Gigabyte Windforce GTX 980Ti, LTT Orange | CASE: NZXT H440 Black 2015 | COOLER: Noctua NH-D15S w/ LTT Fans | RAM: 32GB Patriot 3000MHz | STORAGE: 512GB Samsung 950 Pro, 960GB Sandisk Ultra II 3 x 8TB Seagate HDD's | PSU: 750W Seasonic X series, black / orange cablemod cables| Monitors: 3x Asus VX24AH's | AUDIO OUT: Microlab SOLO 8C, Sennheiser HD 650's, Audio engine D1 Amp / DAC | AUDIO IN: Blue Snowball | Keyboard: CM Storm QuickFire TK MX Green | Mouse: Logitech G900 Proteus Spectrum + RSI Extended Mouse Pad | PCPP Linkhttp://nz.pcpartpicker.com/list/hPjFd6
https://linustechtips.com/topic/270374-is-it-okay/#findComment-3669096
http://pcpartpicker.com/p/nHFB4D $40 cheaper, and better performance.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/270374-is-it-okay/#findComment-3669098
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor  ($189.58 @ OutletPC)
Motherboard: ASRock H81 Pro BTC ATX LGA1150 Motherboard  ($51.99 @ Newegg)
Memory: Mushkin Silverline 8GB (2 x 4GB) DDR3-1600 Memory  ($59.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($51.85 @ OutletPC)
Video Card: Asus GeForce GTX 760 2GB DirectCU II Video Card  ($179.99 @ Newegg)
Case: Cooler Master Elite 350 ATX Mid Tower Case w/500W Power Supply  ($55.46 @ Newegg)
Total: $602.79
Generated by PCPartPicker 2014-12-14 21:03 EST-0500
saved you some money
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/270374-is-it-okay/#findComment-3669204
Thanks for the response guys..
I do want to upgrade the Ram but later on
I will be upgrading it phase by phase
As for the ram, which one should I choose? Any tips?
Also for the graphics card, I usually use Nvidia for my computers at home mainly laptops
Nvidia seems more easier to configure (thats what I thought)
https://linustechtips.com/topic/270374-is-it-okay/#findComment-3685766
Total: $692.81
https://linustechtips.com/topic/270374-is-it-okay/#findComment-3685898
to be honest there is no point by upgrading  " Phase by Phase" That's like doing your final essay but instead of working little by little on it everyday you do one small chunk every week.
https://linustechtips.com/topic/270374-is-it-okay/#findComment-3686076
i5 and a 760 bottlenecking? Not gunna happen. But get 8 gigs of ram instead of 4
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/270374-is-it-okay/#findComment-3686218
