Help 780TI issues
Go to solution Solved by mikeyyve,
I would make sure you are running the latest Nvidia drivers and also that you download something like EVGA Precision X that monitors GPU clock speeds so that you can check and make sure that BF4 is triggering the GPU to increase its clock speed to at least somewhere around 1000mhz.
cpu/gpu temps? it might be thermal throttling
CPU: AMD FX8350 @4.4GHz | MOBO: ASUS Sabertooth 990FX R2.0, 990FX chipset | RAM: 16GB (4x4) dual channel Patriot Xtreme series DDR3 @1866MHz @1.65V | GPU: Asus Radeon R9 Fury Strix| PSU: Corsair AX860i 860 watt | CPU cooling: Noctua NH-D15S + additional Noctua NF-F12 | Case:Corsair C70 Black | Storage: 3x 128GB Samsung 840 pro SSDs; 1 for the OS, 2 in RAID 0 for games. 3x WD Red 3TB HDDs in raid 5 for bulk storage | Displays: 1x Dell 3007WFP 30 inch 2560x1600 IPS LCD. 1x I-Inc IH253DPB 25 inch 1920x1080 TN LCD | Keyboard: Corsair K70 with Cherry MX brown switches + Blue LED backlight | Headphones: Sennheiser HD 280 Pro | Mouse: Logitech G600 @1100 DPI | OS: Win 10 Pro 64 bit |
Mfg/model number: Clevo/W355SSQ | CPU: Intel i7 4710MQ @3.5GHz  | MOBO: W35xSS_370SS, HM87 Chipset | RAM: 16GB (2x8) dual channel Crucial Ballistix DDR3 @1866MHz | GPU: GTX860m 2GB Gddr5 | Battery: 76,960mW/h 8 Cell battery, 3 Hrs full on a full charge | Storage: 1x 128GB Samsung 840 pro SSD for the OS. 1x WD Red 1TB HDD For storage and games | Displays: 1x 15.6" 1080p LCD | Keyboard: Full 103 key back-lit keyboard | Mouse: Logitech M510 | OS: Win 10 Pro 64 bit |
https://linustechtips.com/topic/269803-help-780ti-issues/#findComment-3662131
https://linustechtips.com/topic/269803-help-780ti-issues/#findComment-3662200
http://gyazo.com/d45f56e51caf83feabc5b42c2e41568e would this be the answer to my problems (That is while playing)
https://linustechtips.com/topic/269803-help-780ti-issues/#findComment-3662207
It is possible. 800 mhz isn't TERRIBLE but it really should be higher in my opinion and based on that it really seems like the card is either thermal throttling itself from exceeding the temperature limit it has been set to or the clock speed has been set to only run at 800mhz. Make sure that the temperature limit you have set for GPU boost 2.0 is at an acceptable limit such as 70c or 80c (it is really a matter of opinion on how hot you want it to run up to like 95c where it becomes somewhat unsafe).
https://linustechtips.com/topic/269803-help-780ti-issues/#findComment-3662273
I clocked it 1200 mhz runs like a dream, idk why it started doing this now. it worked fine about a week ago ( no pun intended)
https://linustechtips.com/topic/269803-help-780ti-issues/#findComment-3662784
