Call of Duty Advanced Warfare Crashing
Solved by Guest,
Hmm, do you have pagefile disabled? Or set to something really low like 200MB (the samsung magician software likes to do that)? If that's the case try setting a system managed pagefile on your HDD and see if that works for you (my pagefile usage in AW is ~13GB for some reason). You can also try finding the setting in the config file that determines your video ram, standard value is 0.85, you can change it to 1 (that gives the game 100% of your VRAM to use). Also make sure that you have super sampling completely disabled, it works just fine on my R9 290s.
