when i was trying to get my phone rooted, i had the USB cable plugged into my computer and when i then where thinking on what to do, i had the end of the USB cable unplugged in my hand
so when i went into like a thinking position, that i often do when im thinking about my next move, because the rooting really where not going that well, then the end of the USB cable touched me, and i got a shock.
does anyone know how this can happen, because when i hold it with my fingers (plugged into the PC), nothing happens
Long live Stalin, he loves you; sing these words, or you know what he’ll do!
https://linustechtips.com/topic/269543-usb-electric-shock/
You had a static electric charge that discharged to your grounded PC through the USB cable.
It's called static electricity.
https://linustechtips.com/topic/269543-usb-electric-shock/#findComment-3659185
Most likely the case.
Do not  as I  do, and  not  as I say. Instead do as you may..
HSS Revenir: CPU=i7 5960x @4.5GHz Heatsink=Corsair H100i MOBO=ROG Rampage 5 RAM=Kingston HyperX Predator 16GB @3000MHz SSD=Corsair Neutron GTX 480GB GPU=R9 295x2 PSU=Corsair AX1500i OS=Windows 7 Ultimate
https://linustechtips.com/topic/269543-usb-electric-shock/#findComment-3659228
