Hello everyone, so after 1 week of owning a galaxy note 4 i tought that since it packs the mighty snapdragon 805 then why not playing some serious wicked games :D. And it turns out to be extremely disapoiting. I didnt experience problems with multimedia software at all or any demanding wallpaper whatsoever! But when it comes to playing some mobile games i do experience (low fps). This should not happen correct? In games like Hungry Shark Evolution that pack really good graphics, i noticed that a galaxy note 3 handles it smoothly, wheres my note 4 will not (laggs when diving,eating multiple fish and even when turboing). And it happens on other ones as well (Subway surfers slightly). If anyone knows if this is a defect or something else is causing problem id like to know what to do. Thank you.
Groomlake Authority
https://linustechtips.com/topic/268734-performance-issues-on-note-4/
Are you running anything in the background? If you're using up all the ram (which frankly I find hard to believe) the games might be bottlenecked. Try running a benchmrk and confront it with online results, if it's significantly slower it might be a defective phone. Check if you have some weird power saving setting turned on. They might also be games that weren't properly optimized for the 805.
Don't ask to ask, just ask... please聽馃え
sudo chmod -R 000 /*
I runned at a benchmark (Antutu). My phone gets 47504 and im using only 35% of ram trough cm cleaner analyser. It could be that Shark Evo is not optimized truly :/ and i might just have to give it up. Thanks Sauron
Groomlake Authority
No problem I'm here to help ^^ just out of curiosity, could you try out DIII4A and post back your experience? It runs ok on my nexus 7 2012 with no lighting, I was curious as to how it would perform with a current high end device.
Hey sorry to post this late, but i was unable to even start it out on the phone :P
Groomlake Authority
