Just like what the title says, I know from past experience that 1.65v was the max for x58. My current memory is OC to 2133mhz and the voltage is at 1.65v.
CPU: Intel Core i7-4790K Quad-Core Processor | CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler | Motherboard: MSI Z97-GAMING 7 ATX LGA1150 Motherboard | Memory: Corsair Vengeance 16GB | Storage: Samsung 840 EVO 500GB 2.5" Solid State Drive, Seagate 4TB 3.5" 5900RPM Internal Hard Drive | Video Card: EVGA GeForce GTX 970 3.5GB ACX 2.0 Video Card x2 SLI| Case: Corsair 450D ATX Mid Tower Case | Power SupplyEVGA SuperNOVA 750 G2
https://linustechtips.com/topic/268643-safe-dram-voltage-for-haswell/
well pcpartpicker says that the max voltage for ram using Haswell is 1.5v but you shouldn't have any trouble with 1.65v
PROJECT MOGARCPU: i5 4690k @ 4.9 Ghz CPU CoolerCorsair H100i in Pull on top Motherboard: Gigabyte Z97X-Gaming GT GPU: Gigabyte GTX 1080 G1 Gaming Edition RAM: Corsair Dominator Platinum (2x8GB) 2133 Mhz  PSU: EVGA G2 850W SSD: Samsung EVO 840 250 GB HDD: WD Black 1TB Case: Cooler Master CM Storm Scout II
1.65v is the most commonly rated maximum voltage by RAM manufacturers for DDR3 in general, regardless of platform. Hard and fast rule is that anything higher than 1.75v has some serious potential to insta-kill DIMMs, although there's plenty of crazy OCers out there who will push past 1.8v with the right kit.
Best advice, set the voltage to the rating on the package :D
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
XMP 1.35V, but you can run easily around 1.8+V with Haswell. Its nothing with issues or something. Overlcockers  using 1.85V at air for benchamrks and 2.2V with LN2 at memory. Why? For high memory clocks. Some instability you can tweak with VCCSA voltage and  few tweaks with IO analog and digital voltage.
But from normal user perspective is up to 1.65-1.7V OK.
CPU collection: i7-6700K, 2x-i7-5960x, i7-3930K, i7-4770K, i7-3770K, i7-2600K, i7-980X  AMD PII X4 965 BE C2, x4 965 BE C3, X4 970 BE, x4 975 BE, x4 980 BE, X6 1090T BE, x6 1100T BE, FX-8120 95W, FX-8120 12W, FX-8150, FX-4300, FX-6300, FX-8300, FX-8320, FX-8350, FX-8370E, FX-8370, FX-9370, FX-9590, A8-3870K, A8-5600K, A10-6800B, A10-6800K, A10-7700K, A10-7850K, A10-7870K, Athlon x4 860K, Athlon 5150. RIIIE, RIVE, RVE, Maximus5Extreme, M6F, M6E, M7H, C4F, C4E, C5F, C5F-Z, Crossblade Ranger
