Need a cpu cooler recommendation
so this is going to be an upcoming build (hopefully this weekend) I was originally going to go with a Dark Rock Pro 3 but memory express no longer has it in stock. I have exactly $90 for it and theres only a low chance I can go above that.  please note I am in canada
requirements are:
1. Black
2. under $105 cad if from memory express or if it isnt sold at memory express
3. under $115 cad if from other retailer and available at memory express for a higher price
4. isnt very loud
https://linustechtips.com/topic/268597-need-a-cpu-cooler-recommendation/
NCIX has it in stock in BC. It's $99.99 though. http://www.ncix.com/detail/be-quiet-dark-rock-pro-72-93616.htm
Sorry I misunderstood your 3rd requirement.
CPU: i7-4790K --- HEATSINK: NZXT Kraken X61 --- MOBO: Asus Z97-A --- GPU: GTX 970 Strix --- RAM: 16GB ADATA XPG --- SSD: 512GB MX100 | 256GB BX200 HDD: 1TB WD Black --- PSU: EVGA SuperNova G2 --- CASE: NZXT H440 --- DISPLAY3 x Dell U2414H --- KEYBOARD: Pok3r (Clears) --- MOUSE: Logitech G Pro --- OS: Windows 10
NCIX has it in stock in BC. It's $100 though. http://www.ncix.com/detail/be-quiet-dark-rock-pro-72-93616.htm
too high :/ since it isnt available at ME
not black and looks just as powerful as a 212 evo
ME doesn't carry Be Quiet products at all...
http://www.memoryexpress.com/Products/MX47174
"Rawr XD"
Nope.
What do you mean nope... Why would you get an H55, which performs worse then a 212 EVO in most cases (212 EVO is about on par with H60), and pay twice as much for it?
$10 over my budget
Honestly worth the extra $10, because the only other decent coolers for around $10 cheaper that ME have are the D15, D14 and U14S. All of which are out of stock around here and none of which are black.
"Rawr XD"
Because I can, I don't disagree with your statement. I'd rather have an H55 given the choice.
just remembered I just got paid :) budget just went up a bit
You can pay $10 more for an H100i (which I wouldn't do cause H100i stock fans are loud af), or $40 more for a Nepton 240M (which I also wouldn't do unless you're doing extreme OCs, but even then, we live in Calgary).
"Rawr XD"
if the 240m  was a cent more expensive at ME I could get it for $90 oh well its still in budget
idk, the 240M is great for CM's new fans that are not sold on the shelf, but tbh for that $40 difference you could get some damn good fans to put on the ThermalTake cooler. Up to you.
"Rawr XD"
its $100 - $25 rebate for the 240m sooo... just need my computers buyer to confirm and im off to ME
So you'd rather have a loud, less reliable, worse performing cooler? Why?
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
Build
Mobo: MSI B550 MAG Tomahawk  ||||| Ram: 32 GB GSkill Trident Z RGB ||||| CPU: Ryzen 5800X ||||| GPU: ASUS RTX 3080 TUF OC ||||| Mouse: Logitech G502 ||||| Headset: Sony WH1000XM3 ||||| Keyboard: Logitech G810 Orion Spectrum ||||| Monitors: Acer XG270HU & LG UltraGear 34GP83A-B ||||| AudioStuff: ONKYO DAC HA200 / Audio Techinca ath-ad900x / MXL TEMPO KR USB Condenser Microphone ||||| Storage: 4 TB WD Black --- 2 TB WD Red --- Toshiba 258 GB M.2  ||||| Custom Loop -  Radiators: 3x360 Rad ||||| Case: LianLi O11d XL Black ||||| PSU: Seasonic X series GOLD 1250w
Laptop: Dell XPS 15 9570 4k With a Logitech MX Master
