I want it to be around 25 DBa
PCPartPicker part list: http://pcpartpicker.com/p/172wB
Price breakdown by merchant: http://pcpartpicker.com/p/172wB/by_merchant/
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor  ($199.99 @ Microcenter)
CPU Cooler: Corsair H100i 77.0 CFM  Liquid CPU Cooler  ($99.99 @ Newegg)
Motherboard: Asus SABERTOOTH Z87 ATX  LGA1150 Motherboard  ($268.94 @ Newegg)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($69.99 @ Newegg)
Storage: Samsung 840 Pro Series 128GB 2.5" Solid State Disk  ($129.99 @ Adorama)
Video Card: Asus GeForce GTX 770 2GB Video Card  ($409.99 @ Amazon)
Case: Corsair 600T White Graphite ATX Mid Tower Case  ($149.99 @ Newegg)
Case Fan: BitFenix Spectre Pro 148.7 CFM 200mm  Fan  ($17.98 @ Amazon)
Case Fan: Noctua NF-F12 PWM 55.0 CFM 120mm  Fan  ($26.99 @ Newegg)
Power Supply: Corsair 860W 80 PLUS Platinum Certified ATX12V / EPS12V Power Supply  ($169.99 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($18.99 @ Amazon)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($99.99 @ Newegg)
Total: $1659.81
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-06-16 13:46 EDT-0400)
Should I get a different case and cooler lake a Define R4 and a NH-D14?
https://linustechtips.com/topic/26848-building-a-silence-optimized-build/
The PSU is way to overpowered! You could choose a 500-600w psu, even a passive one if you find one. There are new passivley cooled coming out but i dont know the brand/date.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
A case with noise dampening foam like the define r4 will help with noise reduction, and you can get quiet fans for the h100i so you don't have to change the cooler. And also beware that some people have encountered coil whine issues with the ax 860.
Intel i7-870  //  MSI GTX 670 PE       ///       Intel i7-4500U  //  GT720M
I plan to do SLI in the future
I have chosen 2 NFF12s but for $75 less I can get a NH-D14 and how much noise will be stopped with the noise dampening foam on the R4?
I do really like the aesthetics of the 600T but not sure if its worth getting rid of it
If you're looking for silence/quiet, the Fractal Design Define R4 is hard to go wrong with.
If you really want silence, I wouldn't even overclock so you can have a scythe fan rotate slowly and still cool down the cpu.
You could also use some actual storage. The WD Red 3TBs have thick enclosures and are nearly silent even if you're a few inches away.
The small fan on the sabertooth is definitely not going to help your system's noise level. A much cheaper z87 mobo alternative is suggested.
As for the psu, seasonic makes a line of high end quiet psus called the x series.
I know the Dfine R4 is really silence optimized but lacks aesthetics
It is ither the H100i w/ 2 NFF12 or a NH-d14, Im not too worried about HDD noise, I wasnt going to use the fans on ther sabertooth
There's a reason why the fans are thereon the sabertooth. They vent the air from under the thermal armor.
