Finalizing a build
Go to solution Solved by Paul_VB,
Well.... here you go: http://pcpartpicker.com/p/D6XDMp
1. Budget & Location
Don't really have a budget but nothing crazy expensive. I live in the US but there are no Microcenters around where I live.
2. Aim
Mainly 1080p gaming, school, multitasking.
3. Monitors
3 1080p monitors, game on 1 and use the other 2 for multitask.
4. Peripherals
Don't really need anything but I'll take mice and keyboard recommendations.
5. Why are you upgrading?
Using parts from other builds and got 2 free 3570s. Want equal or better graphics than my PS4/Xbox One.
Forgot to add my parts I have: http://pcpartpicker.com/p/yt6JRB
https://linustechtips.com/topic/268188-finalizing-a-build/
2. Aim
Mainly gaming, school, multitasking.
3. Monitors
3 monitors, game on 1 and use the other 2 for multitask.
4. Peripherals
What parts do you currently have?
CPU: AMD FX8350 @4.4GHz | MOBO: ASUS Sabertooth 990FX R2.0, 990FX chipset | RAM: 16GB (4x4) dual channel Patriot Xtreme series DDR3 @1866MHz @1.65V | GPU: Asus Radeon R9 Fury Strix| PSU: Corsair AX860i 860 watt | CPU cooling: Noctua NH-D15S + additional Noctua NF-F12 | Case:Corsair C70 Black | Storage: 3x 128GB Samsung 840 pro SSDs; 1 for the OS, 2 in RAID 0 for games. 3x WD Red 3TB HDDs in raid 5 for bulk storage | Displays: 1x Dell 3007WFP 30 inch 2560x1600 IPS LCD. 1x I-Inc IH253DPB 25 inch 1920x1080 TN LCD | Keyboard: Corsair K70 with Cherry MX brown switches + Blue LED backlight | Headphones: Sennheiser HD 280 Pro | Mouse: Logitech G600 @1100 DPI | OS: Win 10 Pro 64 bit |
Mfg/model number: Clevo/W355SSQ | CPU: Intel i7 4710MQ @3.5GHz  | MOBO: W35xSS_370SS, HM87 Chipset | RAM: 16GB (2x8) dual channel Crucial Ballistix DDR3 @1866MHz | GPU: GTX860m 2GB Gddr5 | Battery: 76,960mW/h 8 Cell battery, 3 Hrs full on a full charge | Storage: 1x 128GB Samsung 840 pro SSD for the OS. 1x WD Red 1TB HDD For storage and games | Displays: 1x 15.6" 1080p LCD | Keyboard: Full 103 key back-lit keyboard | Mouse: Logitech M510 | OS: Win 10 Pro 64 bit |
https://linustechtips.com/topic/268188-finalizing-a-build/#findComment-3641814
-snip-
We need an actual number, everyone's defenition of "not to expensive" is different
https://linustechtips.com/topic/268188-finalizing-a-build/#findComment-3641825
Forgot to add that, fixed now. thanks
Get a decent ASUS/gigabyte/MSI board for like $130ish-$150ish,
THere are some pretty nice 600ish watt PSUs by corsair for like $50-60
It'd really help if we had an actual number budget Edit: i see your budget is $1000
https://linustechtips.com/topic/268188-finalizing-a-build/#findComment-3641842
https://linustechtips.com/topic/268188-finalizing-a-build/#findComment-3641874
EVGA GTX 970: http://amzn.to/11PxXbh
MSI H97 Guard Pro: http://amzn.to/1xtIhyG
16GB Corsair Vengeance RAM: http://amzn.com/B009M0TCK8
256GB Crucial MX100 SSD: http://amzn.to/1C5S9Xf
2TB Western Digital Black Hard Drive: http://amzn.com/B0036Q7MV0
600W Corsair CX600 Power Supply: http://amzn.to/1pfN34Z
NZXT S340 Case: http://amzn.to/1HDn7Gj
Obligatory PC specs
CPU: Intel Core i5-6600K 3.5GHz
CPU Cooler: Corsair H50
Motherboard: Asus Z170-E ATX LGA1151
Memory: G.Skill Ripjaws 4 Series 16GB (2 x 8GB)
Storage: ADATA Premier SP550 240GB
Storage: Western Digital Blue 500GB
Storage: Western Digital BLACK SERIES 1TB
Video Card: Gigabyte GeForce GTX 1060 6GB 6GB G1
Case: Fractal Design Define S
Power Supply: Corsair CSM 550W
If you are new please read the CoC!
 Please FOLLOW YOUR OWN THREADS!
 Quote people when replying to them.
PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR DARK THEME USERS.
 Mark your problem as solved if answered and like all helpful information.
 DO NOT QUOTE IMAGES(!) just type -pic- or tag them as spoiler.
Don't criticize people for asking "stupid question".
There is actually a hidden search feature on the forums here: Search
IT DOESN'T MATTER IF YOU'RE A FANBOY/FANGIRL. WHAT MATTERS IS THAT YOU DON'T LET THAT EFFECT YOUR HARDWARE RECOMMENDATIONS.
DO NOT POST SPAM!
https://linustechtips.com/topic/268188-finalizing-a-build/#findComment-3641878
Alright, here is the updated list http://pcpartpicker.com/p/pxYk8d
Now what gpu for 1080p gaming driving 3 monitors but only gaming on 1
https://linustechtips.com/topic/268188-finalizing-a-build/#findComment-3641883
He already has ram, storage and a case. That motherboard wont fit his CPU anyway... did you even read his original post?
https://linustechtips.com/topic/268188-finalizing-a-build/#findComment-3641887
a pair of r9 290s or a GTX 970 would be pretty decent for what you wanna do.
https://linustechtips.com/topic/268188-finalizing-a-build/#findComment-3641901
He already has the CPU.  That is what he said in the original post.  And the CPU will fit in that MOBO.
Obligatory PC specs
DO NOT POST SPAM!
https://linustechtips.com/topic/268188-finalizing-a-build/#findComment-3641902
the 3570 is on the LGA 1155 socket. the board you posted has an LGA 1150 socket.
https://linustechtips.com/topic/268188-finalizing-a-build/#findComment-3641914
Oh... sorry.
Obligatory PC specs
DO NOT POST SPAM!
https://linustechtips.com/topic/268188-finalizing-a-build/#findComment-3641916
