Custom PSU cable question
Go to solution Solved by WhatTheQuack,
The 24 pin connector is just that - 24 pins in one connector.
The 20 + 4 pin connector has 20 pins in its main section, and the other 4 pins are in a separate connector.
The 20 + 4 pin Connector is usually used for compatibility with low-power motherboards, which sometimes only require a 20 pin power connector. In this case, it is unlikely that a 24 pin connector will fit properly.
For more 'normal' motherboards which use a 24 pin power connector, it doesn't matter which connector you use, as both are fully compatible.
In your case, I would go for the 24 pin version, unless you are planning on using a low-power motherboard in future.
I am ordering some custom sleeved cables, and I was wondering about the 24-pin cable specifically.  The website I am ordering from has both 24-pin and 20+4-pin options.  Is there any actual difference between these two connectors?
i7-5820k  |  MSI X99S SLI-Plus  |  4x4GB HyperX 2400 DDR4  |  Sapphire Radeon R9 295X2  |  Samsung 840 EVO 1TB x2  |  Corsair AX1200i  |  Corsair H100i  |  NZXT H440 Razer
https://linustechtips.com/topic/268187-custom-psu-cable-question/
My PC:
4670k      GTX 760 ACX      CoolerMaster Hyper 412s      Fractal Design Node 804      G1 Sniper M5      Corsair RM 650      WD Red 1TB     Samsung 840 Evo 120GB
Awesome, thanks.
