Can somebody help me with math?
By
LarsReviews
in Troubleshooting
in Troubleshooting
Solved by mansoor_,
to move all the points on the plane up by 16, you need to move your origin x_{0} = [-9.6,4,2.8] up by 16 in the x3 directions, that way all the point on the plane are translated upwards. Obviously the directions vectors do not change otherwise you will be defining a different plane.
ANS: x_{0} = [-9.6,4,18.8]
where your plane is defined as r = x_{0} + v_{1}*r +v_{2}*s
denizayciceks ·
Posted in Troubleshooting8 -
5
Macaw ·
Posted in Console Gaming5 -
4
2
Shahrad ·
Posted in LTT Releases10 -
9
