Pretty much any atx psu is compatible with the Enthoo pro.
What are you powering? Where are you shopping/located? Budget?
https://linustechtips.com/topic/267383-a-suitable-power-supply/#findComment-3631514
EVGA SuperNova G2 750W - $104 USD
Corsair AX760 - $ 130 USD
EVGA is highly recommended.. What is your specs?
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/267383-a-suitable-power-supply/#findComment-3631555
What's the specification of your computer?
Where are you buying from (links)? What you can get for $150 USD in the US may not be the same as what you can get for $150 NZD in New Zealand.
I live in canada and shop store is newegg.ca
Intel I7 4790k
Gtx 970
Z97Gaming7
Western digital black 7200rpm 3tb
Corsair vengeance pro 1866mhz 16Gb cas 9
Lg bluray read / writer
Noctua nhd 15
Samsung 850 pro SsD
https://linustechtips.com/topic/267383-a-suitable-power-supply/#findComment-3631578
Intel I7 4790k
Gtx 970
Z97Gaming7
Noctua nhd 15
Samsung 850 pro SsD
Are you limited to newegg.ca or are you open to other Canadian shops?
Are you planning to sli?
https://linustechtips.com/topic/267383-a-suitable-power-supply/#findComment-3631603
Nope no sli, and yes i am open to other canadian shops
750w is overkill if you're not planning to sli.
A decent 500w is already more than enough for a single 970: http://ca.pcpartpicker.com/part/evga-power-supply-100b10600kr
https://linustechtips.com/topic/267383-a-suitable-power-supply/#findComment-3631641
But isnt it useful d for when Im overclocking to 1500mhz?
Oc'ing doesn't take that much more power: http://www.hardocp.com/article/2014/09/29/msi_geforce_gtx_970_gaming_4g_video_card_review/10#.VIfnMDHF98E
https://linustechtips.com/topic/267383-a-suitable-power-supply/#findComment-3631677
What about my power consumption, how much do you think my bills would be? ;p
Electricity costs will vary depending on location and usage habits.
https://linustechtips.com/topic/267383-a-suitable-power-supply/#findComment-3631703
I would suggest this Gold rated Semi modular Seasonic G 550W.
http://ca.pcpartpicker.com/part/seasonic-power-supply-ssr550rm
Or this Gold rated XFX XTR which is also a Seasonic unit and fully modular with hybrid fan mode.
http://ca.pcpartpicker.com/part/xfx-power-supply-p1550bbefx
https://linustechtips.com/topic/267383-a-suitable-power-supply/#findComment-3632770
oh ok thanks
https://linustechtips.com/topic/267383-a-suitable-power-supply/#findComment-3633212
