Planing to pump another 200 MHz into my FX-8350 to 4.8 GHz. Right now I have it at 4.6 GHz @ 1.41-1.42V. Now a couple things I need some advice from people that are more experienced then me at OCing.
Temps:
Idle: 1-3C over ambient
Load: 25-30C over ambient
1) Starting voltage? (I was planing to just start @ 1.5V and lower if its stable.)
2) Can I even do it with my motherboard (Asus M5A990x Evo R2.0)? (It's only a 6+2 Phase, and I don't know if it can deliver the power to have a stable overclock.)
Build
Mobo: MSI B550 MAG Tomahawk  ||||| Ram: 32 GB GSkill Trident Z RGB ||||| CPU: Ryzen 5800X ||||| GPU: ASUS RTX 3080 TUF OC ||||| Mouse: Logitech G502 ||||| Headset: Sony WH1000XM3 ||||| Keyboard: Logitech G810 Orion Spectrum ||||| Monitors: Acer XG270HU & LG UltraGear 34GP83A-B ||||| AudioStuff: ONKYO DAC HA200 / Audio Techinca ath-ad900x / MXL TEMPO KR USB Condenser Microphone ||||| Storage: 4 TB WD Black --- 2 TB WD Red --- Toshiba 258 GB M.2  ||||| Custom Loop -  Radiators: 3x360 Rad ||||| Case: LianLi O11d XL Black ||||| PSU: Seasonic X series GOLD 1250w
Laptop: Dell XPS 15 9570 4k With a Logitech MX Master
https://linustechtips.com/topic/267302-advice-for-dem-ocing/
It doesnt matter how much delta over ambient your temps are.
What matters is that they do not exceed 62 degrees, no matter what ambient.
https://linustechtips.com/topic/267302-advice-for-dem-ocing/#findComment-3630451
Oh right, I should put my Ambient, Its around 17.3-21.1C in my room
Build
https://linustechtips.com/topic/267302-advice-for-dem-ocing/#findComment-3630461
