adobe premiere pro help
Go to solution Solved by thekeemo,
check them for what...?
thats its not 1/4 or 1/2 or auto make sure that it full
when I play back a video in premiere, it gets really pixilated..  when I have it paused it looks fine, but as soon as I press play it looks terrible.  I don't have any idea why.  not every video does this, it's just this one (It's a 4 frame loop of my cat running that I made in a different premiere project file).
Maybe the settings I used to export the video the first time don't match the settings in my current project?  I don't really know what's wrong
XEON E3 1231v3 | GA-Z97MX GAMING 5 | XFX R9 290 | 16GB RAM | CRUCIAL MX100 256GB | WD BLUE 1TB | EVGA SUPERNOVA 850W | CORSAIR 350D
https://linustechtips.com/topic/267225-adobe-premiere-pro-help/
okay thanks that helped a lot.  it still doesn't look perfect but it looks a lot better.  did it only look bad for the preview then?  if I had exported it, would it have looked right?
https://linustechtips.com/topic/267225-adobe-premiere-pro-help/#findComment-3629690
yes as long as you dont specify otherwise. also dont forget to click on answered
https://linustechtips.com/topic/267225-adobe-premiere-pro-help/#findComment-3629701
