help what did I do
Go to solution Solved by Jarmore,
Yeah sounds like a powersupply thing, if you boosted up the clocks off the CPU and the GPU then they may be now drawing too much current. What brand is the PSU because even a 400 watt psu should be okay with that sort of gear. I say resetting CMOS is your best bet, returning all clocks to base and it should be okay.
I need help
so i was trying to overclock my GPU with MSI afterburner (HD6670 gigabyte http://www.gigabyte.com/products/product-page.aspx?pid=3832#ov) it was working. but when I shutdown my computer to go into the bios and play with my CPU settings and it wont start. I will hear the beeps that usually occur on start-up but nothing appears on the screen
what did I do?
https://linustechtips.com/topic/26698-help-what-did-i-do/
How many times have you tried turning on your computer?
https://linustechtips.com/topic/26698-help-what-did-i-do/#findComment-339143
What were your temps like?
https://linustechtips.com/topic/26698-help-what-did-i-do/#findComment-339150
Interesting. Those are perfectly acceptable temps, so I wonder what happened.
https://linustechtips.com/topic/26698-help-what-did-i-do/#findComment-339179
https://linustechtips.com/topic/26698-help-what-did-i-do/#findComment-339544
