I have this amp for my micca mb42x speakers
http://www.amazon.com/Lepai-LP-2020A-Tripath-Class-T-Amplifier/dp/B0049P6OTI/ref=pd_cp_e_0
I hear it's a beginner amp, im looking to upgrade it, i see this one has good ratings, is it a much difference, does it make it sound better and louder?
http://www.amazon.com/gp/product/B00A2QLC0O/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=A3H1EWDZP7Z5TC
do yall recommend it, i want the best performance out of my miccas, price range for an amp is maximum 60$
thanks for your time
Professional Graphic Designer on Youtube, HighTech Media.
https://linustechtips.com/topic/266792-audio-amplifiers-please-help/
What's the point?
The output is exactly the same as the Lepai amp. It will have better components in the SMSL amp but I don't see the point.
The output of your speakers is 75 Watts. Why don't you go for a 2x50W amplifier?
My Rig!
Case: Corsair Obsidian 650D, Mobo: MSI Z87-GD65 Gaming, CPU: Intel Core i7 4770K (OC'd to 4.2Ghz), RAM: 16GB Corsair Dominator Platinum 2400Mhz, GFX: 2 x Gigabyte GTX770 OC Windforce in SLI, CPU Cooler: Corsair H100i with Corsair SP120 Quiet edition fans, SSD: 2 x 256Gb Samsung 840 Pro in Raid 0, Storage: 2Tb WD Caviar Black, PSU: Corsair AX760i, Monitor: Benq XL2024T Keyboard: Corsair K70, Mouse: Razer Taipan
Speakers output decibel, not watts. 50W is ~4db gain over 20W, not really worth the extra cost IMO.
Also: I highly doubt that the Micca's can mechanically cope with 2x50W.
I suggest trying the Lepai. Don't like it? Use it for another project and buy a higher power one for these speakers.
Why not buy a used amp you can get a full blown 1970-1990's amp for under $50?
CPU: AMD 3600 GPU: ASUS DUAL OC RX 6750 XT MOBO: Asus Prime X570-P RAM: 16GB XPG Gammix D10 3000Mhz
PSU: Gamdias Kratos P1 650w 80+ Gold OS:Windows 10 pro Case: 4U Rackmount  HDD/SSD:Seagate 8 TB/ Patriot Scorch m.2 512GB
You can't spell ignorant without IGN...-TheSLSAMG
Google 'lepai amp mod'. Basically there's an instruction to replace the lepai's capacitors and potentiometer, to make it sound better. Never tried it though, so I don't know how it will go.
If you're going to get a new speaker amp anyway, try looking for tube speaker amp, if only to get something different, or for the kicks. There are some DIY tube amps on ebay that're not too pricey.
