hi,
i recently built a computer wiith the 760t.
everything has been alright the past few days however i left my computer on for a few hours without activity and noticed the power light for my case is off but it can still work. Is it possible to make it light up without going for and RMA? i had custom water cooling so it would be a hassle to do everything again.
https://linustechtips.com/topic/266767-760t-power-lights/
Lights?
CPU: Intel I7 4790K 4.8 Ghz || Mobo: ASUS ROG Maximus Hero 6 Z87 || Ram: Corsair Vengeance 16 GB 1600 Mhz || GPU: ASUS GTX 980 Ti STRIX || Storage: 2 x SSD Samsung 840 EVO 250 GB RAID 0 HDD Western Digital 1 TB Black || PSU: Corsair AX 860 watt || Cooling: 2 x AF 140mm (front), 2 AF120 Blue LED (bottom and back), 2 SP120 (top on radiator) ||  CPU cooler: Corsair H100i GTX || Case: Corsair obsidian 750D <3 <3 <3
https://linustechtips.com/topic/266767-760t-power-lights/#findComment-3623904
pardon me for not making myself clear but it is basically the power button does not light up
Restart and see if it starts working again. If not then you may need to RMA. Either way Corsair will be better equiped to handle this so I suggest getting in contact with them.
Edit* But I mean you can always mod it so you can use a new LED. It shouldn't be too hard
Sky Pollution | i5 3570k @4.8Ghz | MSi z77a g45 | MSi GTX 770 Gaming 2gb | Samsung 840 Evo 250gb, Samsung OEM 500gb HDD | Corsair CX750m | Corsair 760t White Edition |
Corsair M95 | SuperLux 668b's | Logitech C615 | ViewSonic VX2250wm | Random OEM keyboard until I rage break it and grab another random OEM keyboard from my pile.
Build Log: http://linustechtips.com/main/topic/186413-sky-pollution-my-white-760t-build-rebuildupgrade/
https://linustechtips.com/topic/266767-760t-power-lights/#findComment-3623925
I don't know the 760t, but on most cases, you can take off the front panel, buttons, etc. without dismantling the whole PC - and RMA only that part.
If RMA doesn't work and you know someone that does electronics and/or light-mods, he/she could certainly diagnose and fix it easily.
And just out of curiosity: Did you check the polarity? Maybe it's just +/- that's the wrong way around (happens often).
https://linustechtips.com/topic/266767-760t-power-lights/#findComment-3624075
