Noctua Fan
Solved by Peter Vaughan Truslow,
Hey,
One of my noctua fans on my radiator(pull) is not giving the same airflow as the other noctua fan. What should i do?
if they're connected to the motherboard fan controller, it's probably as simple as them not being controlled on the same fan curve. if one of them is connected to the CPU fan header, and one is connected to a chassis fan header, that is likely the culprit as most CPU fan headers will have a lower minimum speed especially when PWM
