Hi,
I made a topic about my GPU but i want to know about CPU save temps so i got 50 oC on my 4 core i5 proccesor (each core has 3,1 GHz) while playin AION with some high quality option setup and with ts3 communicator plus browser ofc . , is it good ? In addition to that this proc has like 2 years already (although he wasn't used for like 3 months).
CPU i5 6600k 4,4Ghz , COOLER Dark Rock 3 from BQ, RAM 16 GB of ddr 4 2800MHz from corsair,
 PSU EVGA 750 W GOLD G2, MOBO Msi z170A Gaming M3, CASE NZXT H440 Black/Blue,
GPU Geforce GTX 980 Gigabyte G1 Gaming,
STORAGE 1 SSD Samsung 850 Evo 250 GB and 1 HDD 500GB WD, Windows 8.1.
https://linustechtips.com/topic/266374-cpu-save-heat-temperature/
system info to include cooling
It's the same in my GPU topic that you have answered but okay, It's air  cooler ofc which simple radiator with fan on top , on the left side its a 20mm fan i think(but not sure for 100% since itwas attach with case), on top of my case there is PSUP corsair 750, unfortunetly PSUP fan is directed on motherboard .-. , motherboard is gigabyte b75m-d2v and case is open for 24/7.
70C is the sweet spot for both Cpus and Gpus. Generally as long as your temps are below 70C you're fine. So, to answer your question, yes that's a fine temp to be sitting at under load and seems normal for the speed of the processor.
Fx-6300 @4.4Ghz  -  Gigabyte 990FXA-UD3  -  Sapphire Dual-X R9 280 @1100/1325mhz  -  16Gb of GSkill Sniper Series Ram @1866mhz  -  EVGA SuperNova G2 750w Psu
Thank you all for answers
