I currently have a H60 bought a while back when all the hype was around about them sadly i hate it, Cant keep my cpu cool and the 120mm rad heats the rest of my case up.
Soo i wordering if i should stay with these pre made water cooling packs or just get some air cooling ?
whats the best air cooling for cpu these days ?
https://linustechtips.com/topic/26599-cpu-cooler/
how do you have it mounted?
Cpu: Intel i7 4770k @4.4 Ghz | Case: Corsair 350D | Motherbord: Z87 Gryphon | Ram: dominator platinum 4X4 1866 | Video Card: SLI GTX 980 Ti | Power Supply: Seasonic 1000 platinum | Monitor: ACER XB270HU | Keyboard: RK-9100 | Mouse: R.A.T. 7 | Headset : HD 8 DJ | Watercooled
https://linustechtips.com/topic/26599-cpu-cooler/#findComment-337992
NH-D14 or Silverarrow if you want to go extrem.
Are your fans working correctly with your H60? o.O
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/26599-cpu-cooler/#findComment-337993
i have it mounted at rear of the case sucking new air in and 2 frount fans pushing air out and a 200mm fan on top push air
try switching the back fan to out and the front to in, that should fix your problem
https://linustechtips.com/topic/26599-cpu-cooler/#findComment-338030
i have it mounted at rear of the case sucking new air in and 2 frount fans pushing air out and a 200mm fan on top push air in
and also turn the 200mm intake around, the normal way of heat is going up but now its pushed down in the case again.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/26599-cpu-cooler/#findComment-338038
I would say always get water cooling over air cooling.
an h60 is about on par with a hyper 212 evo in most situations .....and for the cost you could buy a decent phanteks,thermalright,noctua heatsink.....so yeah don't always buy water cooling,especially if it's AIO.
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
https://linustechtips.com/topic/26599-cpu-cooler/#findComment-339282
But the h60 is a prefilled that is just to say to your friends that your computer is watercooled.
https://linustechtips.com/topic/26599-cpu-cooler/#findComment-342683
