[SOLVED] Front usb not working
Go to solution Solved by J_DeMan,
I've never updated since I got the board
Give it a try than.
There is a yellow error sign in device manager next to Intel c600/x79 series chipset usb2 enhanced host controller #2 - 1D2D
CPU- i7 5960x MOTHERBOARD- Asus Rampage V extreme RAM- 32gb Corsair Dominator Platinum ddr4 2800mhz GPU-  2X EVGA GTX 980 SC in SLI PSU- Corsair ax860 CASE- Corsair Obsidian 750d COOLING- EK cpu+dual gpu custom loop (ek supremacy evo, dual gtx 980 copper/acetal waterblocks) MOUSE- Logitech g502 proteus core KEYBOARD- Ducky shine 3 cherry mx blue switches and blue LED MONITOR- Samsung u28d590d UHD  STORAGE -  120 gb samsung 850 evo ssd, 960 gb ocz trion ssd OS- Windows 10 pro http://pcpartpicker.com/p/jtP8GX
https://linustechtips.com/topic/265961-solved-front-usb-not-working/
Usb wire is fully plugged in to header on motherboard
Is your bios up to date? That fixed a similar problem with my Z97-A.
Give it a try than.
i disabled and re enabled it and they're working now. thanks
