http://pcpartpicker.com/p/mKBpNG
Hi,
I am almost done with my pc but i can't seem to find the psu " Seasonic X-650 (SS-650KM3) 80PLUS Gold" in pc partpicker
even with the compatibility filter off.
so I was wondering if it would be ok for my pc.
If not what kind of 650w psu would you reccomend?
The brands available(at least 15 different models) in Belgium are: Be quiet, coolermaster, corsair and seasonic
thank you for the help.
https://linustechtips.com/topic/265176-need-help-for-a-psu/
Are you planning to sli?
The x650 is otherwise overkill.
https://linustechtips.com/topic/265176-need-help-for-a-psu/#findComment-3604740
yes, I am planning to sli
Then I would go with the EVGA G2 750W (Albeit a bit overkill on the wattage), EVGA NEX 650W or similar PSU's
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/265176-need-help-for-a-psu/#findComment-3604769
A 750B2 would be plenty: http://de.pcpartpicker.com/part/evga-power-supply-110b20750vr
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/265176-need-help-for-a-psu/#findComment-3604788
(my bad)
i would also go for evga but Evga is almost non existent in belgium (looked on 4 websites only 3 psu available in each)
Edit: didnt see it was in germany (might give it a try)
Edit 2: is the difference between 80+ bronze and 80+ gold noticeable?
https://linustechtips.com/topic/265176-need-help-for-a-psu/#findComment-3604800
(my bad)
Can you link us to where you're shopping if the link I provided won't do?
The difference between bronze and gold can be noticeable but only makes a slight difference in extreme cases.
https://linustechtips.com/topic/265176-need-help-for-a-psu/#findComment-3607895
http://www.ldlc.com/informatique/pieces-informatique/alimentation-pc/c4289/
there is also amazon.fr, however the price i get on ldlc are better and the website has an excellent reputation.
there is also rueducommerce which is the cheapest but it doesnt have a good reputation.
sorry it's in french so i will try to translate the criterias there are
constructeur = company that produce it.
puissance = power
prix = price
utilisation type : kind of use
ordinateur de bureau : desktop computer.
https://linustechtips.com/topic/265176-need-help-for-a-psu/#findComment-3609116
puissance = power
prix = price
Raider S 750: http://www.ldlc.com/fiche/PB00150487.html
Thanks for the translation--although Google translate is usually fine for navigating a pc shop.
https://linustechtips.com/topic/265176-need-help-for-a-psu/#findComment-3614518
