So I've been asking, reading , watching and researching what's the best cooling and set up for fans with style. I'm confuse with a lot of things and don't even know where to start.
So I have the carbide 540 in white, i7-4790k.
Side note first , I'm getting the h105 cpu cooling. (Or should I get h100i or h110?)
Anyway for my set up.. My questions are as follows.. Also please for SP, should I use performance or quiet edition?
Linus said on video that SP on push and AF on pull is best. But I keep seeing people use 4 SP on their radiator..
Front fans: 2 AF or 2 SP 140?
Rear or exhaust: 1 140 AF or SP?
For push pull: top radiator 2 SP 120?
Bottom : 2 AF 120?
For all my AF I will use with white led.
Please help me!
https://linustechtips.com/topic/265126-fan-build-and-push-pull/
i usually will opt for static pressure fans for intakes with filters in use.
rear i/o usually is exhaust so a airflow style fan works best in that location,
unless the rear mesh is highly restrictive, then the static work best.
radiators self-explanatory. static pressure. some loose radiator fin arrays
can get away with airflow. but more often than not a static is know best
flow-rate.
bottom again, filtered would be static.
https://linustechtips.com/topic/265126-fan-build-and-push-pull/#findComment-3604309
Any other thoughts guys ?
Please help :(
Please don't get Corsair SP. There's plenty of better fans for the money, if not cheaper.
Desktop: Intel Core i5 2380P (2400 w/o iGPU), MSI H61, 8GB RAM, 256GB SP610, 500GB WD Blue, HIS R9 280, Antec TruePower Classic 550W, Inwin MANA 134, QNIX QX2710, CM QuickFire Rapid, Logitech G402
Laptop: Toshiba Satellite L40D, AMD A6-6310, 6GB RAM, 500GB HDD, Radeon R4 Graphics, 14" 1366x768
Phone: iPhone 6 Space Gray 64GB, T-Mobile $60/mo 3GB plan
https://linustechtips.com/topic/265126-fan-build-and-push-pull/#findComment-3606039
https://linustechtips.com/topic/265126-fan-build-and-push-pull/#findComment-3610399
