Need help with Gaming/Content Creating PC
Solved by 79wjd,
Get a second 970 in the future, other than that...it looks good.
A gigabyte G1 gaming 970 would be better though (i'd also get a different case as a G1 gaming won't fit)
The CX600 is half the cost at Newegg (or alternatively, get an EVGA G2 750w instead as its a much better psu)
/If you have a microcenter near you then you can get a 4790k+mobo combo for quite a bit off the usual price...if you don't, then add $50~ to my builds total cost.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($249.99 @ Micro Center)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler ($102.74 @ Amazon)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard ($134.99 @ Micro Center)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1866 Memory ($123.99 @ Newegg)
Storage: Crucial MX100 128GB 2.5" Solid State Drive ($62.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($52.89 @ OutletPC)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card ($359.99 @ Amazon)
Case: Phanteks Enthoo Pro ATX Full Tower Case ($99.99 @ Newegg)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($89.99 @ NCIX US)
Total: $1277.56
Generated by PCPartPicker 2014-12-06 13:12 EST-0500
