I am sleeving my cables on my OCZ and I noticed that the wires arent "straight over" from the PSU plug to the GPU side, meaning the bottom left cable from the PSU side doesnt go into the bottom left slot on the GPU side. I'm thinking the PSU manufactures can do whatever output diagram they like as long as the input diagram is the same?
I am thinking that I have to be carefull to put them back in the same slot I take the plug of out even if it makes it look crossed when using different colours. Right?
/Luri
https://linustechtips.com/topic/264472-cable-sleeving/
Do them in singles, pull one and sleeve it, then put it back in and pull the next one.
If mixing sleeve colours you can buy cable combs to help make sure things are in the right order in the areas where it actually matters. Not sure where to get them in Denmark though. May need some international shipping.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/264472-cable-sleeving/#findComment-3597332
  • 2 weeks later...
/Luri
PSU makers all have their own pinout on the powersupply side and it varies widley. However on the motherboard side it is an ATX Standard that has to be kept.
[MAINFrame Customs Shop] | [Sleeving Guide Videos] | [Sleeving FAQ]
[Project Log]:[ Katharos ]: April MotM Winner | [Project Log]:[ Xýlo Kai Chalkó ]: Working | [Project Log]:[ Aspros ]: Done - 4th Place PDX Lan |
[Reason I Live]
https://linustechtips.com/topic/264472-cable-sleeving/#findComment-3678323
Thanks for the info. :-)
I've decided to do extension cables instead and make a bend acrylic piece to hide the psu. I'll pull the extension cable through rubber grommets to hook up to the psu cables below.
The crossed wires was messing with my OCD so couldn't have it. :-P
https://linustechtips.com/topic/264472-cable-sleeving/#findComment-3679134
