So i just bought the parts but i decided to ditch the motherboard ( msi 970a-g43 ) after some bad experiences other poeple had..
This are my specs:
Cpu: AMD FX-6300
Gpu: sapphire r9 280
Hard drive: WD 1 TB
Case: bitfenix comrade
Ram: Crucial balistix tactical dual channel 8 gb
Power supply: XFX ts 550W
What motherboard shall i choose for this build? Keep it cheap please.
https://linustechtips.com/topic/264445-replacement-for-my-build/
I would go for either the ASRock 970 EXTREME4 or MSI 970 GAMING. Just for future upgradability.
However, if you want something cheaper, the Asus M5A97 R2.0 and Gigabyte GA-970A-UD3P are good choices.
Laptop: Intel Core i5-4200H, 8GB RAM, 750GB HDD, GeForce 840M
Desktop: Intel Core i3-6100, 8GB RAM, 750GB HDD, GeForce GTX 750 Ti
https://linustechtips.com/topic/264445-replacement-for-my-build/#findComment-3596806
