yeah obviously rom or kernel issue.
https://linustechtips.com/topic/264302-m8-wi-fi-issues/#findComment-3594905
the rom is meant to be 100% working so it must be the kernel, what do i have to do to fix a kernel?
OP states that you should be running latest 4.4.4 htc kernel before installing this ,so yeah i assume that is the case and also I am not sure about how to flash a stock kernel on htc devices _assassin_ would know
https://linustechtips.com/topic/264302-m8-wi-fi-issues/#findComment-3594935
i am downloading a kernel now will i have to wipe everything and then install the kernel or install the kernel while using the custom ROM in the recovery
https://linustechtips.com/topic/264302-m8-wi-fi-issues/#findComment-3594951
be on the safe side wipe data but you can try it without wiping it first
https://linustechtips.com/topic/264302-m8-wi-fi-issues/#findComment-3594985
