I just want people's opinions on the build I'm about to order, is it good? I'm aiming for 1080-1440p gaming for FPS games mostly, also for every day use like web browsing.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (£173.94 @ Aria PC)
Motherboard: Asus MAXIMUS VII RANGER ATX LGA1150 Motherboard  (£125.20 @ Aria PC)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  (£80.39 @ Aria PC)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  (£280.00 @ Aria PC)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case  (£88.79 @ Aria PC)
Total: £930.10
Generated by PCPartPicker 2014-12-04 19:57 GMT+0000
I'm not worried apart from anything except from the power supply. Will it suffice? I don't plan to OC in the near future unless the benefits are massive.
https://linustechtips.com/topic/263837-some-final-advice/
I think you get get a cheaper motherboard, cheaper ram, cheaper case, and a better psu and a second 970
If not, it should be okay.
https://linustechtips.com/topic/263837-some-final-advice/#findComment-3588416
Benefits from OC are massive, but I would reccomend using HyperX Fury (If you want you could get one red and one black dimm) (Unless you picked for looks) because it is cheaper, and if you want better performance, with that money you saved on the RAM get a G1 :P
My current build - Ever Changing.
Number 1 On LTT LGA 1150 CPU Cinebench R15
http://hwbot.org/users/TheGamingBarrel
https://linustechtips.com/topic/263837-some-final-advice/#findComment-3588419
look into the nzxt s340 case? IMO it's nicer than the h440 and it's cheaper too.
-BUILD-
CPU: INTEL I5 4690K GRAPHICS CARD: GIGABYTE 970 G1 2.5GB CASE: NZXT S340|BLACK MOBO: MSI Z97S KRAIT EDITION CPU COOLER: CORSAIR H100i
 RAM: HYPERX FURY 2X4GB|WHITE PSU: CORSAIR RM850 850W FULLY MODULAR STORAGE: 1TB WD BLUE HDD OS: WINDOWS 8.1
https://linustechtips.com/topic/263837-some-final-advice/#findComment-3588496
The Hyper X Fury 8GB 2x4GB 1600 kit is £7 cheaper than the GSkill X Ripjaws 2133, what G1 would you suggest also?
https://linustechtips.com/topic/263837-some-final-advice/#findComment-3588619
This one, http://www.scan.co.uk/products/4gb-gigabyte-gtx-970-g1-gaming-7010mhz-gddr5-gpu-1178mhz-boost-1329mhz-1664-cores-3x-dp-1x-hdmi-1x-d
970 is great :D Getting it for my system.
https://linustechtips.com/topic/263837-some-final-advice/#findComment-3588634
Care to suggest some alternatives while not going over my budget of £930?
A tiny bit over, and 2 970's was a bit over 1000
http://uk.pcpartpicker.com/p/yRNTNG
Single 980 beats single 970
https://linustechtips.com/topic/263837-some-final-advice/#findComment-3588962
