OK Now im currently undertaking a build Rough Budget of about $4-500 max at $650 in planning but i found myself doubting the build specs and parts i have picked out are NOTE All parts are coming From Newegg
Case is by DIYPC Model Number on new egg DIY5823BK Now this case i picked because price the problem with the case is it come with 1 pre-installed 80mm rear fan and an optional 80mm fan on the side panel now in the case pictures provided by Newegg other mounting holes are visible but what is the size?? there is also no detailed max CPU cooler height Motherboard compatibility is ATX/Micro ATX. Suggestion for a new case is welcome
MotherBoard Is By Gigabyte The boards Model Number on newegg is GA-B85M-DS3H I choose Gigabyte because i heard good mentions about there products even though they may be expensive. Now the board has only one system Fan header which is a small drawback i would like to utilize both spots for fans on the case and it has An LGA 1150 Socket. again i AM up for suggestions But i would prefer to stick by MSI,Gigabyte,ASUS, or even Asrock.
CPU Ok hold Your Cringes the chosen processor is of course by Intel, The model number on newegg is BX80646G3220 Its a 3.0GHz Dual core Haswell Processor, Pentium Series. Now Im not to sure about this processor but i do prefer intel over AMD But i am open to suggestions.
The PSU Is By Diablotek Model Number on Newegg PSDA400 Now i would have more tried to stay near more talked about brands but this one was cheaper and it did meet the power connector needs. Open for suggestions Of course
Included Simple CD Rom reader writer nothing special
For HDD/SSD For A Mechanical HDD i went with a Seagate Barracuda 1Tb Drive and A 120Gb SSD Samsung 840 EVO. Now the HDD is for sure decided on now the SSD im not sure on Reliability and price i was planning on having the OS and Drivers on the SSD. Open for suggestions.
RAM Chosen is From G.skill RipJaw X series. 8gb 2x 4gb. I much rather prefer having my Ram Work Through Dual Channel so i went with 2 sticks instead of a single. Open to ideas on this piece as well
Simple Wireless Card From Asus Model PCE-N15. Wifi Capability is important. And Final is New fan i would rather stray from Original Case fans to Corsair or Cooler Master
SATA Cables i already have covered. And Simple Windows 7 32bit Because we had a windows 8 all in one for a time and i do not enjoy its interface
https://linustechtips.com/topic/263326-cheap-rig-need-some-help/
Can you post a pc part picker link and what will you primarily be using this system for?
https://linustechtips.com/topic/263326-cheap-rig-need-some-help/#findComment-3582080
This sounds right in your budget
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor  ($90.98 @ Newegg)
Motherboard: ASRock FM2A78M-HD+ Micro ATX FM2+ Motherboard  ($52.99 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory  ($59.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($52.65 @ OutletPC)
Video Card: EVGA GeForce GTX 750 Ti 2GB Video Card  ($109.99 @ Newegg)
Case: Cooler Master N400 ATX Mid Tower Case  ($54.98 @ Newegg)
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply  ($19.99 @ Newegg)
Optical Drive: LG GH24NS95 DVD/CD Writer  ($19.96 @ OutletPC)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($89.98 @ OutletPC)
Total: $551.51
Generated by PCPartPicker 2014-12-03 19:35 EST-0500
Edited by Ramamataz
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/263326-cheap-rig-need-some-help/#findComment-3582512
Total: $551.51
This build does infact work it does infact lack a SSD And i do try to refrain from AMD processors
https://linustechtips.com/topic/263326-cheap-rig-need-some-help/#findComment-3582797
I wouldn't go with that processor seeing that it doesn't even have hyper threading so if you were to try and play FC4,Unity and COD AW you wouldn't able to because it requires four cores
https://linustechtips.com/topic/263326-cheap-rig-need-some-help/#findComment-3583051
