A week or two ago, my computer started showing a CPU fan error randomly when I boot sometimes. The fans are spinning and they show on ai suites and HWMonitor. I tried switching fans but the same happened. It gets temporarily fixed by restarting.
Asus  Maximus hero VI
coolermaster hyper 212 evo with 2 fans
i7 4770k
7950
Edit: I should note that my computer is about a year old and not just built
https://linustechtips.com/topic/262757-random-cpu-fan-error/
Yes but based off the update notes, it doesn't look like it will fix the problem
Give it a shot at least...
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/262757-random-cpu-fan-error/#findComment-3574880
It still might. You can compare the version on your system by holding the windows key and hitting R, then typing in "Dxdiag.exe" in the run box and hit enter. Hit yes when it asks about digitally signed drivers, and on the main page it will say BIOS: then a version. You can compare the version YOU have to the version that's available on ASUS's website. If the version on ASUS's website is newer, it's worth getting.
https://linustechtips.com/topic/262757-random-cpu-fan-error/#findComment-3574885
I finished updating and tried rebooting a few time and it hasn't done it yet. If it happens again I'll post again
https://linustechtips.com/topic/262757-random-cpu-fan-error/#findComment-3574996
Good to hear. Hopefully that resolves the issue.
Also, doesn't the rampage have 2 CPU fan headers? If it does have you tried both of them with the same results?
https://linustechtips.com/topic/262757-random-cpu-fan-error/#findComment-3576406
I use both because I have 2 fans on my cooler.
Also I turn on my computer for the first time today and it happened again. Not sure what to do now
https://linustechtips.com/topic/262757-random-cpu-fan-error/#findComment-3582947
