Hi guys, I just found a monitor and I wanted some advice before buying it.
Here it is : http://www.iiyama.com/gb_en/products/prolite-xu2390hs-1/
I am looking for a monitor around 150€ and mainly for gaming, so if you can help, I'd really appreciate it as it's very difficult to make choices ^^
Also people say IPS panels are way better than TN panels, so I prefer privileging panel quality over response time, even though the monitor I linked is only 5 ms.
https://linustechtips.com/topic/262502-help-for-future-purchase/
iiyama are a good company thats the company i think i am going to get my monitor from being reading alot of reviews of all types of there monitors and other products as well and they seem solid and good with the few bad reviews but things like glossy finish and that which obviously doesn't effect perforamnce.
https://linustechtips.com/topic/262502-help-for-future-purchase/#findComment-3572088
I was wondering which one to choose between this one http://www.iiyama.com/gb_en/products/prolite-xu2390hs-1/ and this one http://www.iiyama.com/gb_en/products/prolite-xb2380hs-1/
They have both the same specs, however they have different bezels and screen rotation.
Do you think the bezels one the second one are big ?
https://linustechtips.com/topic/262502-help-for-future-purchase/#findComment-3572131
