I was looking to put more fans on my pc and was wondering if there were any cheap 120mm fans. also i wanted the rubberized mounts if you guys know where to find the rubber mounts seperatley that would be great because i have 3 fans on my pc.
CPUi7 5820k
MotherboardAsRock x99 extreme4
RAM16gb (4x4gb)
GPUgtx 980ti zotac amp
CaseNZXT Phantom Windowed Edition Black
Storage2tb hdd and Crucial MX 200 250 gb SSD
PSU750 watt cool master
Display(s)2 monitors both 1080p
Cooling80mm water cooling for cpu
KeyboardRazer Ultimate 2013 mechanical
KeyboardMouseRazer Hex Naga (green gloss)
Operating System windows 10
https://linustechtips.com/topic/261703-fans/
the cheapest fans that i know of that are good and come with rubber mounts are rosewill hyperborea, the 120mm are around 10$ i think
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/261703-fans/#findComment-3563792
