Which takes better pictures?
CPU- i7 5960x MOTHERBOARD- Asus Rampage V extreme RAM- 32gb Corsair Dominator Platinum ddr4 2800mhz GPU-  2X EVGA GTX 980 SC in SLI PSU- Corsair ax860 CASE- Corsair Obsidian 750d COOLING- EK cpu+dual gpu custom loop (ek supremacy evo, dual gtx 980 copper/acetal waterblocks) MOUSE- Logitech g502 proteus core KEYBOARD- Ducky shine 3 cherry mx blue switches and blue LED MONITOR- Samsung u28d590d UHD  STORAGE -  120 gb samsung 850 evo ssd, 960 gb ocz trion ssd OS- Windows 10 pro http://pcpartpicker.com/p/jtP8GX
https://linustechtips.com/topic/261145-6-plus-camera-vs-note-3/
from what i heard, the camera on the 6 and 6 plus are pretty decent.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/261145-6-plus-camera-vs-note-3/#findComment-3558088
6plus. (4k is video...)
Yeah, usually still images have much higher resolution than videos. 4K resolution is about 8mp and most Android smartphones have cameras greater than 8mp, which will mean it can capture stills at greater than 4K, but as most people know, megapixels aren't the be all, end all for camera quality. But imo, 4k video captures are really gimmicky, the only advantages are the higher bitrate so if you downsample it to 1080p, then you'll have a really good video, but left in 4k, it's rather lackluster.
https://linustechtips.com/topic/261145-6-plus-camera-vs-note-3/#findComment-3558314
