G-sync has a module that needs to be place inside a monitor
you need a G-sync capable monitor to take advantage of G-sync
I am asking if the feature is supported by the GPU, I know I need a g-sync module in the monitor
Want a good game to play?  Check out Shadowrun: http://store.steampowered.com/app/300550/ (runs on literally any hardware)
another 12 core / 24 thread senpai...     (/. _ .)/     \(. _ .\)
https://linustechtips.com/topic/261116-g-sync-help/#findComment-3557950
really, no support for any mobile graphics?
https://linustechtips.com/topic/261116-g-sync-help/#findComment-3557977
