Hey, im Currently 13 Years old
and i wanna upgrade from a Intel Duo T9300 2.4Ghz, nVIDIA 8800m and 4gb ddr2 ram to a better light gaming build!
And i will mostly play these games
Far Cry 4 / GTA V / Unturned / The Forest /DayZ / ARMA III / just openworld games etc... And also some CS : GO, And i need to be able to record bo2 med settings at 60fps very important ! :D
I Will also Render Short Clips 20-40 Secs with Sony Vegas and AE
Here you can Find my Specs
https://www.mindfactory.de/shopping_cart.php/basket_action/load_basket_extern/id/1969fc22084cb011a0c1494a9f3bcb597cc8d1510a17a9ce225
thanks for any help :)!
https://linustechtips.com/topic/261103-need-help-with-new-pc-quick/
You're gonna need more RAM and a better GPU if you want to do what you described, what's your budget?
PC Specs:
CPU: i7-9700k  | Motherboard: Gigabyte Z390 Aorus Elite | RAM: 16GB's Team T-Force Vulcan 3000MHz | GPU: Zotac GTX 1070 8GB AMP! Edition  | Storage: 500GB WD Caviar Blue | 1TB WD Caviar Black | Crucial BX200 240GB SSD | OS: Windows 10 64-bit  | PSU: EVGA SuperNOVA G2 650W 80+ Gold | CPU Cooler: Noctua NH-D14 | Mouse: Logitech G502 Proteus Spectrum Headphones: Sennheiser HD 598 Special Edition's, HD 598 Cs | Keyboard: CM Storm QuickFire XT MX Blues Monitors: Acer GN246HL 144Hz, Acer G226HQLBbd 60Hz | Case: Phanteks Enthoo Pro.
