I have a problem with my memory, please help
I have just built a new pc and when I start the pc I get no video and on the motherboard is there a little screen that says Fe, and if i press rest then my motherboard goes 13-15-fe I have read that It could be the memory that is not working but I tried with the memory from my other pc and I still said fe.
Please comment if you know anything about this and btw my motherboards is the Maximus hero VII and my ram is 16gb 2400 mhz from corsair, and the other ram I tried was just an 4 gb stick and I don't know how much mhz it had or where it was from.
https://linustechtips.com/topic/260976-i-have-a-problem-with-my-memory-please-help/
Read the manual
CPU: AMD Ryzen 7 3800X GPU: ASUS Strix Radeon R7 5700 XT OC Edition Motherboard: ASUS Crosshair VIII Hero RAM: G.Skill Trident Z DDR4-3200 CL14 SSD: 2x Samsung 970 EVO Plus 1TB PSU: Corsair AX860 Cooling: NZXT Kraken X72 Case: Corsair Crystal Series 570X Mirror Black Display: BenQ XL2420Z  Keyboard: Corsair K95 RGB Cherry MX Blue Mouse: Logitech G502 Proteus Spectrum Audio: Logitech G633 Artemis Spectrum
I have two times even, but could not find a thing about it
I just read the manual and it seems like there's no FE on the Q-code. Try reseating (take out, put back in) your RAM (I'm assuming you know if the RAM is properly seated).
