here's a little trick for you:
Capital B means the longer word, BYTE
Lowercase B means the shorter word, BIT
Edit: ACCIDENTALLY CREATED EMOTICONS, GODDAMN IT LTT!!
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/260949-storage-speed/#findComment-3560081
Hi there @Chriz6097!
The different sized hard drives will work in RAID 5, but keep in mind that RAIDs can only use the size of the smallest drive to build with. For instance, if you have a 10MB, 10GB and a 10TB drive in RAID5, there will be a 30MB RAID5 created (3*10MB) .
Hope this helps.
Cheers! :)
If this post helped you, please like and choose it as a best answer.   :)
http://www.wdc.com/en/
https://linustechtips.com/topic/260949-storage-speed/#findComment-3561563
