Have you installed any programs recently? Do you use video editing software like Premiere? In the past I have had programs like Premiere cache a lot of data in hidden folders like AppData.
CPU: i7-4790K --- HEATSINK: NZXT Kraken X61 --- MOBO: Asus Z97-A --- GPU: GTX 970 Strix --- RAM: 16GB ADATA XPG --- SSD: 512GB MX100 | 256GB BX200 HDD: 1TB WD Black --- PSU: EVGA SuperNova G2 --- CASE: NZXT H440 --- DISPLAY3 x Dell U2414H --- KEYBOARD: Pok3r (Clears) --- MOUSE: Logitech G Pro --- OS: Windows 10
https://linustechtips.com/topic/260749-help-ssd-problems/#findComment-3553763
over a course of this week my ssd went from like 50 gigs to like 8 gigs, how the fuck do I check what is taking up so much room :D
Windows Updater. xD It adds a lot. Also look up your windows page file (A file that stores data for your cpu to use if your ram is full) and reduce the size of it. It defaults at some huge amount, like 200% of your total ram (Don't quote me on that).
https://linustechtips.com/topic/260749-help-ssd-problems/#findComment-3553801
