Corsair uses their own pin-out for their PSUs, as such, they will not be compatible with Antec PSUs.
Unless you sleeved them yourself or find someone that will provide a sleeving service (like Lutro0 for example), you will need to buy extensions like the Bitfenix Alchemy.
https://linustechtips.com/topic/260526-i-need-help/#findComment-3551250
First off welcome to the forums. You don't need to title it "I need help!" This great community will always help you. :D Just call something like this, "PSU cable management help"
Anyways to answer your question, as far as I know the sleeves wont work with the PSU as you need to use the same brand.
Obligatory PC specs
CPU: Intel Core i5-6600K 3.5GHz
CPU Cooler: Corsair H50
Motherboard: Asus Z170-E ATX LGA1151
Memory: G.Skill Ripjaws 4 Series 16GB (2 x 8GB)
Storage: ADATA Premier SP550 240GB
Storage: Western Digital Blue 500GB
Storage: Western Digital BLACK SERIES 1TB
Video Card: Gigabyte GeForce GTX 1060 6GB 6GB G1
Case: Fractal Design Define S
Power Supply: Corsair CSM 550W
If you are new please read the CoC!
 Please FOLLOW YOUR OWN THREADS!
 Quote people when replying to them.
PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR DARK THEME USERS.
 Mark your problem as solved if answered and like all helpful information.
 DO NOT QUOTE IMAGES(!) just type -pic- or tag them as spoiler.
Don't criticize people for asking "stupid question".
There is actually a hidden search feature on the forums here: Search
IT DOESN'T MATTER IF YOU'RE A FANBOY/FANGIRL. WHAT MATTERS IS THAT YOU DON'T LET THAT EFFECT YOUR HARDWARE RECOMMENDATIONS.
DO NOT POST SPAM!
https://linustechtips.com/topic/260526-i-need-help/#findComment-3551261
