Hi,
At the moment im looking into trading my gaming laptop with a gaming pc, and i was offered this;
Intel 920
XFX 7870
14GB Kingston RAM
500GB HDD
Corsair H50
Windows 7
I want to know if this will be any good for gaming?
Thanks
Someone wants to trade you this?
That should be good to go and run just about any game at high and get 40 frames avg I'd say (on games like Bioshock, Total War, Guild Wars, Need for Speed)
OS - Windows 8.1 Motherboard - ASUS M5A99FX Pro R2.0 Processor - AMD FX 8350 Black Edition RAM - 16GB 2x8 Crucial Ballistix Sport Graphics Card - Gigabyte Windforce 2 OC GTX 660 Power Supply - Corsair CX750M CPU Cooler - NZXT Kraken X60 Wireless Adapter - ASUS PCE-N15 PCI-E Adapter Fans - x3 Masscool blue LED 120mm Fans Case - Fractal Design Define R4
Monitor - Dell S2230MX 21.5-inch Keyboard - Logitech G105 Mouse - Logitech G602 Speakers - Logitech Z130 Headsets/Headphones - Tt eSports Shock, AKG K240, California Headphones Laredo Phone - iPhone 4S
I think the CPU will bottleneck the GPU so you'll probably have to game at 720p.
I think the 920 still have life in it.
You know that the 920 is almost as fast as an i5 2500k?
Yea well that isn't that good either, or I've just gotten used to using overclocked extreme series processors. lol
<p>Wires Suck :angry:
!fY0|_|(4|\|R34[)7#!5PMM37#3(0[)3:1337 70833|\|73R3[)!|\|49!\/34\|/4Y 4|\|[)93741!f3
i5 2500k is more or less the standard,it can run pretty much any single or dual graphics configuration without being the bottleneck
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
Thanks guys :)
And yeah someone wants to trade this, apparently its in excellent condition and can still run most games.
If it turned out that it couldn't, are there any other CPU's that will run in this socket?
what gaming laptop are you trading for this system?specs?
just want to know because we could give you an approximate value for your system.and for his system,and see if it's a good deal for you.
overall it's a pretty solid system.only things I would look into.
-is it a genuine installation of windows
-what power supply is in it (don't want some shifty power supply that craps out)
-ask to see stress tests like prime95,furmark,and some DX11 benchmarks like heaven,valley,or 3d mark run to make sure it's not half dead already
The ram is a waste..you'll never need more than 3-4 in games...i would suggest 6-8 gigs probably on 1333
he isn't buying components for the system,he's trading someone his laptop for the desktop......
At the moment I'm looking into trading my gaming laptop for a gaming pc, and i was offered this;
-snip-
It should be good for most games. Some CPU intensive games, such as Guild Wars 2, may have lower fps on occasion (because of the 920), but overall it's fine.
To get full use out of the RAM, and since you're probably going to re-format, make sure to install Windows 7 64-bit. (Even if the original Windows is 32-bit, you can install 64-bit using the same key.)
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
