i plan on getting this CPU to replace my a10 APU, but i have a question, will it bottleneck any single GPU i thow at it???
i mean in the future to get something like a 980 or a 290x, or whatever comes out with the release of the AMD 300 series GPUs.
thanks in advance,
have a cookie
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/260183-i5-4440-question/
No. I dont even have to explain, look at my sig
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/260183-i5-4440-question/#findComment-3547894
its good, but since you are spending alot on gpu why not get 4460
i am talking about the future, i will run my 270x meanwhile i get the money
https://linustechtips.com/topic/260183-i5-4440-question/#findComment-3547903
it's a good CPU but a modest one, i would consider pairing it with a GTX 970 but not much more than that.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/260183-i5-4440-question/#findComment-3547922
