Check your background processes. Something is putting stress on that processor so you need to find out what and close it. Open task manager and click on processes, there is everything. Right clock on it and chose "end all process tree."
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/260122-high-cpu-loads-when-idle/#findComment-3547204
It passed the test, everything is ok but it says that I only have 2 physical cores and 4 logical. Does that mean that I only have a dual core?
Its acting as a dual core with hyperthreading.  You should have 4 physical cores, and 8 threads.
Might have to go into BIOS and correct something.  Maybe something got disabled accidentally?
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/260122-high-cpu-loads-when-idle/#findComment-3547278
Has it always been this way? It's rare but it's possible that something is wrong with 2 of the cores. I RMAd my 4770k last week when Core 0 started failing at stock. I wouldn't say do this right now, but try to remember if it's always been like this or just recently.
And see if the motherboard BIOS is the latest version!
4k Main Rig: CPU: Intel 4770k || MOBO: MSI Z87-GD65 || GPU: 2x GTX 780 DCIIs || MEM: 4x4Gb 1600MHz Corsair Vengeance || CASE: Corsair 750D || STORAGE: Corsair 240Gb Force GS (OS), Corsair 120Gb Force GT (games) and Seagate 3TB (storage) || PSU: Corsair 860i || DISPLAYS: ASUS PB287Q 4k || COOLING: 360mm x 45mm Rad, 280mm x 60mm Rad, EK Supremacy EVO, 2x EK GXT 780 ti DCII blocks
https://linustechtips.com/topic/260122-high-cpu-loads-when-idle/#findComment-3547378
Do you think if I'd press the bios reset button on my Mobo?
yes start with that.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/260122-high-cpu-loads-when-idle/#findComment-3548011
