So i posted a couple days ago and i got a lot of great help but i still have questions i cant seem to answer and i also just want others opinions in general. So i am building a gaming PC, the requirement are for it to not be out of date too fast if possible, able to do far cry 4 and other current and future games in nice graphics as best as possible, be as good as possible in general for at most $1,500, but not over kill for a 15 year old and also to save money if possible. hopefully that is a good description. anyways, he will be in 1080p all the time i would say. and the graphics card is something i'm unsure about a bit but i feel i chose okay. i was hoping to do two of the graphics cards but i personally cant seem to make it work. i do know some or a lot about computers but i'm not a genius at it all so any and all the help i can get would be a big help. if you have any ideas to make this thing amazing for a 1,000 to 1,500 price range that would be great for me. here is a link to the amazon wish list i have to know what i am getting and everything. i know amazon is not the cheapest with everything though.  http://amzn.com/w/3L3L7GKXER69P
https://linustechtips.com/topic/259825-need-help-with-first-build/
try goin to the link above if you haven't tried that or wasn't helpful
Hi friend.Who are you?
unless that case is really worth it you could get a different one
try a samsung 840 evo
now  think about a better graphics card maybe also mainly it's about the moniter not just that stuff and when I ment the link it should have been a youtube one from me not your amazon link
now  think about a better graphics card maybe also mainly it's about the monitor not just that stuff and when I meant the link it should have been a youtube one from me not your amazon link
Thank you for your help! i was thinking two of the asus strix gtx 970 but its too expensive and i cant get anything too much better because it seems to always end up too expensive. but i am not a pro at this so i'm probably not including a lot of different cards. if the water cooling i have is way too much i could get something cheaper and see if that helps and all but it still is pushing it i feel.
try a Corsair Hydro Series High Performance Liquid CPU Cooler H60
your welcome
unless that fan isn't good enough then your perfectly fine
unless you want me to go even deeper into the depths of amazon
I will be on tomorrow if you  need anything else
